Cheers Rich
RST wrote:My only experience was when I had my Aristo a few years ago.![]()
Bought new discs and pads from them amongst other bits)
-the discs and pads lasted about 300 miles before they were shot and needed replacing.
I haven't bought from them since as they fell to the bottom of the supplier list, but a gates belt should be a gates belt I guess.
I found some stuff from them was under a different name
-e.g.
I don't mind Blueprint, Delphi etc, but some of their stuff I thought wasn't OEM equivalent
(hence the cheapness).
MR2 Rich wrote:Thanks JD, they have a water pump with the thermostat housing as well which I was thinking of buying.Can't find anywhere else that sells the complete unit and not just the water pump on its own.
ElvisRockVinyl wrote:they cater for imports as i find that with mine things like timing belt kits are identical to that ik the uk model.
Peter Gidden - SBITS wrote:ElvisRockVinyl wrote:they cater for imports as i find that with mine things like timing belt kits are identical to that ik the uk model.
Corrected for you.![]()
ElvisRockVinyl wrote:I've had front brake pads which are on 60k now
ashley wrote:ElvisRockVinyl wrote:I've had front brake pads which are on 60k now
Your brake pads have lasted 60k miles??
Do you use the brake pedal(the one in the middle)?
ElvisRockVinyl wrote:ashley wrote:ElvisRockVinyl wrote:I've had front brake pads which are on 60k now
lol haha yea just don't drive like im having trouble taking off, use the engine a lot to slow me down
Brakes last 60k- clutches
