Options? is there a small terminal battery available with a bit more oomph.
Do i go for a bigger battery and change all the supply cables and
Do i change the battery clamping method which i am inclined to do as the
Do i move the battery to the frunk or use one of the battery's that the racing boys use.
This question must have been asked before as woodsport seems to think the original fit is ok if you want to set light to you car.
Any info however mad graitfully received.
