So im thinking just to change the engine for a much lower mileage one instead of faffing around changing the clutch and then probably having to do the cambelt and headgasket
from what ive seen you can get a rev 2 3sge a fair bit cheaper than the rev 3+ 3sge but performance wise is there any noticable difference? because if not I will just source a rev 2 one.
Cheers!
