[Mk2] [Turbo] new hot pipe
slipping clutch
Post by slipping clutch »
I am currently making some pipe work up to fit my charge cooler - I need to put the small hump in the pipe to stop the silicone pipe work slipping off - can any one tell me what this process is called? I thought it was a "swage"
but apparently its not - I have tried a number of local engineering companies to get his done and am coming up blank. I am now resorting to telephoning other companies farther out and asking them but it would help if I knew the proper name for the process :oops:
Even better if your Near Wiltshire and can do this please drop me a line :cheers:
slipping clutch
Re: [Mk2] [Turbo] new hot pipe
Not my pipe but its the process I am after
Magic Beans
Post by Magic Beans »
Bead rolling? That's what I'd have called it anyway :-k
slipping clutch
Think you may have nailed it there Mr. Beans. Thank you sir. :thumleft:
Magic Beans
slipping clutch
Bead Swage !!!!!! is what I am after - can any one help?
Peter Gidden
Post by Peter Gidden »
Diameter?
slipping clutch
Mr. Gidden to the rescue again ! Thanks Peter, I'm off out to the garage to have a fiddle :D
Peter Gidden
slipping clutch wrote:Mr. Gidden to the rescue again ! Thanks Peter, I'm off out to the garage to have a fiddle :D
slipping clutch wrote:Thanks Peter, I'm off out to the garage to have a fiddle :D
slipping clutch
took a picture of me having a fiddle !
jimGTS
Post by jimGTS »
its bead rolling
youtube it
its like a press that pulls out a small amount.
where to get it done though, no idea!
mark239
Post by mark239 »
a couple of beads of weld is all you need to do.
david123
Post by david123 »
mark239 wrote:a couple of beads of weld is all you need to do.
as above,
Done this before on someones boost pipe. Just ran a run of tig weld.
Doesnt even have to be a ful fun, just a few beads to stop the clamp from blowing off
slipping clutch
