It started after I replaced the thermostat, I already bled the coolant twice.
jon_st205 wrote:Did you make sure the thermostat was orientated properly with the casing?
BIGBOBO wrote:jon_st205 wrote:Did you make sure the thermostat was orientated properly with the casing?
You have to align it?![]()
Guess I found my problem.What should I align, are there markings on the thermostat?
Lauren wrote:Surely considering the cheapness it's a no brainer to pick up an OEM one?
