Peter Gidden - SBITS wrote:If mounted to gearbox with OEM GT4 bracket(as Craig's is), i see no reason for MOT guy to have an issue.
Marf wrote:Also I don't see how the gearbox will create undue vibration?
shinny wrote:Marf wrote:Also I don't see how the gearbox will create undue vibration?
Well the gearbox is directly bolted to the engine so all vibrations created by the engine(which are capable of vibrating my entire car through polybushed mounts) will be transmitted through the gearbox housing to the pump.
Marf wrote:And the GT4 was well known for suffering from pump failure because of engine vibrations?
I think you're overthinking it.
The pump bracket has rubber dampers on it anyway, or at least mine did![]()
mark239 wrote:I'm sticking a massive chargecooler on my car, decided to use a Mk1 Focus RS chargecooler pump, as they were reasonable money brand new.
jimGTS wrote:from my research when i did my own custom CC setup, i read alot of reports that the closer the pump is to the rad the better..
i personally mounted it under the passenger headlight!
no danger of damage there!
ignore crazy bends at rad, i fit a 45degree in the end
http://url.photobucket.com/albums/v326/ ... 8_2447.jpg
http://url.photobucket.com/albums/v326/ ... 8_2471.jpg
sheppy wrote:jimGTS wrote:from my research when i did my own custom CC setup, i read alot of reports that the closer the pump is to the rad the better..
ah man, this looks way better!!!
RedMR² wrote:sheppy wrote:jimGTS wrote:from my research when i did my own custom CC setup, i read alot of reports that the closer the pump is to the rad the better..
How is it'way better' than it being mounted on gearbox?
well i can go over speedbumps without fear of ripping it off![]()
