Track car with a low budget | Powered by Adaptronic
GreddyMR2
Re: Track car with a low budget | Powered by Adaptronic
Post by GreddyMR2 »
matt-mr2 wrote:
GreddyMR2 wrote:Wiseco forgies. Hope they are stronger than stock :)
Image Replaced With URL For Quote http://imageshack.us/a/url13/2806/bj0v.jpg
You got a bargain there forgies of £100 :thumleft:
Yep, that's why I like Lithuania :D Here is no demand for 3sgte parts, but also supply....
DB Mr2
Post by DB Mr2 »
Only just read through it all, what a change from when you first got it!
Congratulations on the trophies as well :thumleft:
GreddyMR2
Post by GreddyMR2 »
DB Mr2 wrote:Only just read through it all, what a change from when you first got it!
Thanks, appreciate that! :)
Little by little, it's changing to track car... I would still like to have one clean 2 for daily driving :)
GreddyMR2
Post by GreddyMR2 »
Have just realised how the wing helped me in a corners. Take a look at both videos. The same suspension, the same tyres (even they were worse in a run with a wing). I think the difference is obvious, even from the video :)
With a wing:
http://www.youtube.com/watch?v=xjpjtndlpm8
Without it:
http://youtu.be/BPr8i5eEY9w
For the next season - front splitter on a list :)
Magic Beans
Post by Magic Beans »
Looks to be doing it's job well :)
If you're feeling a difference and seeing an improvement in lap times, then I think it's a job well done :thumleft:
GreddyMR2
Post by GreddyMR2 »
Magic Beans wrote:Looks to be doing it's job well :)
It's hard to say about lap times, because the track configuration was different.
In the slower track configuration with a wing my time was 1s slower. But the result in my group was better, so I think it's a progress :)
GreddyMR2
Post by GreddyMR2 »
Some progress with rebuild.
Finally the engine is back! Fitted wiseco forged pistons, clevite racing bearings, fidanza exhaust cam gear, all new cometic gaskets.
Still lots of work to do with other parts, but the main job is done!
The manifold and turbo were gasket matched.
Do you think it's needed to take the manifold to smooth the surface or is it smooth enough?
Also started modifying intake manifold. Still have to make a thick gasket of aluminum to cover that hole in throttle body.
Not sure what to do with cold start injector... The one from 3sgte manifold does not fit in 3sge manifold. Do you think I can use injector from 3sge?
GreddyMR2
Post by GreddyMR2 »
Some time went through, not so much work done...
Some engine parts were sand-blasted. Intake manifold and valve cover is now being powder coated by silver and red. I hope to pick them up this Friday and will be able to put on the engine :) Also, I am waiting for turbo water gasket. Arter I have it, I will start mounting exhaust side. Now the engine block and pan was painted.
Body works have started. It looks worse than it looked with all body parts in places :)
What do you think about exhaust mani gasket? OEM or Cometic?
GreddyMR2
Post by GreddyMR2 »
Have picked up powdercoated parts and fitted them on the engine to take a quick look :) I'm starting to like how it looks.
GreddyMR2
Post by GreddyMR2 »
We have an interesting idea!
As you already saw my bodie's condition, you could agree it will be really difficult to fix all those rusts. And you saw not everything...
So, we are now thinking of cutting the car in a half and then fit another back from the car I have in great condition. That car it's RHD, so we can't just put everything in that body.
If we decide to do this, it should be interesting... :D
Couple more photos of this evening.
Fitted new manifold, but had to remove engine hang.
Magic Beans
Looking good :)
Would it not be easier to buy a new shell and to swap your parts over to it? I'd always be worried about racing something which has been cut in two :-k
Engine looks good mate. As Phil said, I'd re-shell rather than cut and shut 2 shells together. :pale:
GreddyMR2
Post by GreddyMR2 »
I agree with you both, but there are couple of problems.
Here in Lithuania at the moment there are 2 MR2s for sale, both N/A. The cheapest cost over 1300gbp. And still can't be sure about its condition, need to check. And I don't have enough money for it... Also, if I will put everything into N/As body, I would need to take a car to inspection, which again cost a lot of money. If I could find LHD turbo body in good condition and for a good price, that would be nice. Unfortunately it's not possible.
We are still thinking what is the best solution.
About being afraid, if it's done well, nothing will happen :)
Magic Beans
Hmm, I see your problem :-k
I'd still be a bit worried about cutting a car in half and then racing it though. If done properly it could/should be ok. Others who have a better understanding of this than me will be able to give you a more informed opinion :)
GreddyMR2
Post by GreddyMR2 »
Thanks for your reply :)
So we made a decision now. It's to cut it in a half, make some reinforcements here and there + fit a rollcage. Then it must be strong enough!
The guy who will do cuting and welding, have lots of experience of doing this kind of jobs, so I feel confident enough.
To buy another shell would cost similar, but I will have a rollcage instead and will feel much more confident during racing.
A cut and shut car will never be as strong as the original monocoque chassis.
I certainly wouldn't rely on a cut and shut, whoever put it together.
GreddyMR2
Post by GreddyMR2 »
I know it's probably not popular in UK, bet here in Lithuania it's quite normal to do such things. I agree it's not as good as monocoque body, but with a rollcage I shoudn't worry, I think.
GreddyMR2
Post by GreddyMR2 »
We decided to transfer my Pinkie into full track car :)
It will have fia certified roll cage and other things needed to get it fia approved.
I began with a seat :)
Today the shells should be cut in a half. After welding them, car will be taken to fit a roll cage.
Now some small progress on the engine:
Fitted new head to manifold and manifold to turbo studs to prevent blown gaskets.
Bought some bling bling :D
GreddyMR2
Post by GreddyMR2 »
Got a couple of pics from my friends that are working on my car :)
Og God it looks frightening :shock:
Magic Beans
:o
Are the parts where the two cars are being joined together getting extra strengthening?
