Bent my new one, so removed it.
What tools/items have folk used to sussessfully knock this in without damaging the seal?
New idea was I found a plastic drain pipe which is ni on same size, maybe 1-2mm smaller than the seal inside the seal lip.
Only worry is the thickness of the pipe, maybe 2mm.
Would be better to find something thicker, or even solid I'd guess?
Ideas from those that have done this before with no problems?
Old seal
