When someone asks me to build a custom 6 speed with LSD i have to buy three gearboxes just to build one, a C52, a Mk3 5 speed LSD box and a Celica C60.
IanParkhouse wrote:My LSD gives the car a desire to understeer when applying power in bends.
stenky wrote:By no means does Quaife or torsen give power to the inside wheel.The idea is that it biases torque of the wheel with less torque
(inside) and adds it to the wheel with more torque
(outside) under uneven torque distribution
(weight transfer during cornering).
Polypedates wrote:OK, I'm certainly tempted but would be looking for an option that retains as much of the original parts as possible but particularly the standard gearbox.
Is there a direct fit LSD for the Mk1 anymore?
Fab4MR2 wrote:stenky wrote:By no means does Quaife or torsen give power to the inside wheel.The idea is that it biases torque of the wheel with less torque
In the case when the vehicle is turning and neither wheel is slipping, the inside wheel will be turning slower than the outside wheel.In this case the inside wheel will receive more torque than the outside wheel, which can result in understeer.
IanParkhouse wrote:there's a tendency to plough straight on
After 9 years I'm pretty used to the handling of a Mk1 by now and Ian Clements will confirm I can make full use of all grip in the corners.![]()
