After 2 years of being off the road I decided to get my ar$e into gear and buy another car.
Started by looking at MX5's, but discovered I don't fit.
After a few months of looking, I found one in London and set off to get it, after a 12 hour journey I was back home with it.
It's a 1996 Azure Blue MR2 GT, 143,000
Only got a few photos since I've had it, Instagram obviously:
So it came with a few extras:
5Zigen Exhaust
A'PEXi Induction Kit
17" Mitsubishi Evo wheels
A few little bits needed doing, so so far I've removed the sunstrip, stopped one of the front wheels rubbing, removed a switch that disabled the headlight motors, replaced the drivers mirror as it was smashed, fixed the horn wiring, replaced a worn gear knob, moved the air filter heatshield as it was blocking air from the air intake.
Went through the MOT 2 weeks ago with 2 advisories
Going to be quiet until January, at which point this will get a full service, clutch and timing belt change and maybe some HSD coilovers.
