I'm having trouble fault finding a misfire that my rev3 turbo has.
I've removed my Unichip to take that out the equation.
I've changed the spark plugs, checked dizzy cap and rotor arm, all is fine and fairly recent, all Denso parts and NGK plugs.
I've check the coil pack and checked all the earths I could find but nothing has helped.
I've had a look for air leaks but all vacuum pipes have been renewed lately.
No error codes found, I did have one for oxygen sensor but I replaced the lambda for a blueprint part which cleared the code but still have the misfire.
Anything else I can check? I'm running out of ideas quick and just want it sorted!
Cheers, Michael.
