Many people will know this car well.
Youtube video of class-winning run here:
http://www.youtube.com/watch?v=BuBIe40JZQA
This car was built with no expense spared.
Power is en excess of 550bhp, and torque is 530ftlbs.
Specification is as follows:
Freshly built in 2010.
Camry 2.2 1998 cylinder block
Custom JE Pistons
Carrillo con rods
Camy crankshaft
ACL Race series big end and main bearings
ARP main bearing cap studs
New Toyota Camy oil pump
New Toyota MR2 water pump
HKS stopper head gasket
ARP cylinder head studs
Rev3 cylinder head crack tested and leak tested
1mm oversize inlet and exhaust valves
Inlet and exhaust tracts ported and port matched
Custom ground camshafts from Kelford Cams
Kelford Cams valve springs
Adjustable cam gears
HKS cambelt
New Toyota tensioner
All gaskets, O rings and seals etc.
Remote oil filter
Rotating assembly fully balanced prior to assembly.
ATS Racing GT35R with re-routed Tial wastegate.
Precision chargecooler
Boot mounted high capacity pump
Radtec front mounted radiator
Boot mounted ice box
Radiator or ice box selected by T taps under car
With ice box selected, condensation will form on chargecooler.
O.S.
Rev3 Turbo
CRW uprated CV joints
Twin in-tank 255lph fuel pumps
Pumps directly wired to battery using heavy duty cable
Twin Goodridge
Large bore fuel rail configured as deadhead.
Aeromotive fuel pressure regulator
Goodridge
1ZZ COP coil packs with custom wire loom
Syvecs Motorsport ECU inc.
4 Pot Brembo Front Calipers
325mm Diameter Discs.
Braided brake Lines all round
Electronic line locks installed in front brakes operated by button on steering wheel.
Rays Engineering Volks 17 Alloys
Toyo Proxes R888 with less then 1500 miles of use.
Rear: 245/40 ZR17
Spare set of 17 wheels with Goodyear Eagle F1 with no visable wear.
Fronts: 215/40/ZR17
Rears:
Engine Oil
Gearbox Oil
Coolant
Brake ans Clutch Fluid
Tenzo seats
AEM Wideband 52mm gauge
SPA Dual Digital 52mm gauges reading:
Oil temp
Oil pressure
Water temp
Boost
Chargecooler water temp
Engine mapped by Ryan at 2BarTuning
This car will be supplied fully serviced with new MOT.
All invoices i have issued will be supplied, as will dozens and dozens of build photographs.
Price is
Will deliver anywhere in UK or mainland Europe
