I am fitting a replacement head to my rev 3 turbo.
Can anyone with more knowledge than me advise?
Chris
chrishewett wrote:I seem to be having a problem buying the head gasket I need.
I am fitting a replacement head to my rev 3 turbo.The block is standard
( just honed) and the head has not been skimmed.
With the je pistons this should give a compression ratio of about 9-1 with a 1.00mm gasket.
I wanted to buy a 86mm 1.2mm metal gasket but the only one I can find is an athena at
£140.
I was hoping to buy one cheaper than that.
I am told that the cometic, at
£89, is 87mm and suits all bores.
I am not very happy with reducing the gasket between the bores when I don't have to.
Also, I can only find a cometic in 1.3mm.
Chris
What piston to head clearance have you designed the engine for?
chrishewett wrote:What piston to head clearance have you designed the engine for?
The engine is as I bought it.All this is guess work.
I will attempt to measure the clearance when the head is off.
Meanwhile I am trying to get an idea of what gasket will be safe.I havn't been able to find a single supplier who seems to know much about what they are selling.
TCB dont even know the thickness of the gasket they supply, simply saying that
" everyone uses them".
My local toyota suppliers don't know the thickness of the standard toyota gasket.
I'm not even sure whether the thicknesses quoted are before or after being crushed.
JE state that the cr with a 1.00 mm gasket on a standard block and head is 9-1 so I am wanting to lower that slightly as I will be boosting at 1.1 bar or maybe a bit more.
As you can tell I am not very knowledgeable on this subject so any guidance would be gratefully received.
chrishewett wrote:Why ever would JE produce pistons for this engine which gave a 9-1 cr?
chrishewett wrote:Uk websites are selling pistons for the 3sgte at 9:1
