yeah i have got to the stage where i am angry everything is done, and it just won't run...
it has ran, but badly, found timing one tooth out, changed, re checked about 5 times..
it ran idled but hunted for about a minute then died. assumed an air leak..
did a smoke test on the engine found a hole in manifold i had failed to blank, blanked off
always suspected the afm was a bit dodgy so got another from a breakers apparently from running car
also today put 5 litres of fuel in to make sure had enough, then change fuel filter as had a dent in it..
engine reads no fault codes at all just flashes as it should
dizzy set in the middle
has a spark, checked compression several times..
and it just won't start.. turns over fine no problem just won't fire..
i really just want it done now so i can enjoy it but tis driving me mad!!!
please where do i go...
p.s. in case you dont know its a mk1 mr2 rev 1 engine with rev 2 ecu and loom and any plugs needed changed over.. but like said its run and i even manage to drive it on the drive
wired using a motorsport wiring man using paul manual..
[Mk1] [Turbo] rev 2 turbo.. please help.. a little depressed now
Re: [Mk1] [Turbo] rev 2 turbo.. please help.. a little depressed now
Sounds like it still has a leak in the boost pipes some where, I had the same problem and it turned out to be 1 of the silicone hoses that joins the charge cooler to the boost pipe had a split in it underneath so u could not see it
Thanks but
Nope no leaks as used pressure smoke on the inlet to push smoke out of any holes
Hmm,
Hmm,
Is there fuel getting to the chambers?
If you've been trying to start it repeatedly without luck, there's a strong chance the plugs have been fouled. Try cleaning them or better yet, chuck a new set in.
Id say something in wiring, have you got correct ignitor for rev2?
yep checked the ignitor with Peter gidden that its the right one..
yeah i am going to clear the plugs tomorrow afternoon, then go through all the wiring but like sid it had run...
Well..
back to basics. As my grandad said you need air, fuel and a spark.
Are the plugs wet?
Are you getting fuel?
Are you getting a spark?
Pulled the plugs 1 by 1?
Correct order?
AFM stuck open?
Are the plugs wet?
Correct order?
AFM stuck open?
moscoworbust wrote:Well..
Are the plugs wet? nope will clean them up tomorrow to double check
Are you getting fuel? thats the question i have fuel, but is it getting in?
Are you getting a spark? i did have, again going to start from scratch
Pulled the plugs 1 by 1? yep
Correct order? yep
AFM stuck open? nope just got it
how do i know if the injectors are working and actually get fuel in
thanks
pistol pete wrote:moscoworbust wrote:Well..
Correct order? yep
thanks
The spark plugs will be wet.
well it stopped working again last night.. and with the leads being brand new as well as the plugs. Patrick said maybe to coil letting go under pressure when trying to run the engine
so i had a look and it was covered in silicon
peeled that off and found this..
do we think this si the issue??.. oh i do hope so...
Looks like a likely culprit!
Definitely seen better days
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
