[Mk2] [NA] 1996 mr2 with airbag can i replace with new mr2 mk3 steering airbag
sergy355
Post by sergy355 »
as the above says i have old type airbag steering wheel want to change to celica rev 7 or mr2 mk3 still want the airbag to work
thanks
serge
Nic
Re: [Mk2] [NA] 1996 mr2 with airbag can i replace with new mr2 mk3 steering airbag
Post by Nic »
sergy355 wrote:as the above says i have old type airbag steering wheel want to change to celica rev 7 or mr2 mk3 still want the airbag to work
thanks
serge
You may need an adapter harness to connect the airbag, the Toyota part number is 09082-00760 do a Google image search though first to check it has the correct plugs for your steering wheel.
Nic
[email protected]
MR2 Rev 3 GT Turbo
sergy355
Post by sergy355 »
ok thanks il buy the steering wheel of ebay first then look . is it worth bying the lead just in case
are the boss all the same
sergy355
Mechanical airbag
Post by sergy355 »
Just took my steering wheel of but I have a mechanical airbag
Take it I can't fit airbag to car only wheel
Any ideas
