[Mk2] [NA] ACIS blue connector plug is broken = ok to leave it out?
vrooom
Post by vrooom »
The 2 pin blue plug that plugs into thingy on back of inlet manifold, its part of acis vacaum system.
I ripped the wire out of the connector while I lifted the head whilst doing the headgasket. it was really oily mess there.
will it affect the running of the car? or ok to leave it out?
Peter Gidden
Re: [Mk2] [NA] ACIS blue connector plug is broken = ok to leave it out?
Post by Peter Gidden »
You could leave it broken. But you'll be down on torque/power.
If you need a plug and tails off a loom, PM me.
Return to “Electrical”
