Engine has got Hks 264 cams
86.5mm cp pistons
Eagle rods
All bearings and studs replaced by the usuals
Currently running with standard fuelling, ecu and turbo.
Runs very smoothly when any throttle is engaged, even just holding the throttle to run it at 850-1000 rpm and it runs fine, but as soon as you let off the throttle it will stall.
Cam and ignition timing is set as it should be, injector seals have been replaced as believed it was a leak from around that area, all pipes have been checked and checked again, and no engine error codes being displayed when you perform the diagnostics trouble code procedure.
Can anyone suggest anything/ experienced something similar?
Matt
