Due to the snow here ive been reading up about tvis and from what i read the system operates by both vaccum
Alex
charged wrote:Mine's probably screaming'stop raping me'
JMR_AW11 wrote:On my car I modded the factory code in the ECU to let me change the TVIS operating point so I could set the ON and OFF rpm thresholds where I wanted.
This is the most accurate way to do it because the ECU also switches in some ignition advance with the TVIS activation.So it's best to keep all this in sync.
