heads up
heads up
Recieved a special notice yesterday on vts, all the changes to mot are due to come in to effect as of 20th march.
So all you boys running HID lights beware
Mr2 Rev1 tubby
http://www.imoc.co.uk/forums/garage.php ... e&CID=4217
my build thread
my build thread
Re: heads up
maybe finally i won't be getting blinded by every HID installed SUV behind me now.
Re: heads up
yep
no more chavs with cheapo hid lights
Mr2 Rev1 tubby
my build thread
my build thread
Re: heads up
You reckon?
Most shitty HIDs are probably in cars owned by people who know bribe friendly testers.
I hope it makes some difference but I don't expect much.
Re: heads up
Mr2 Rev1 tubby
my build thread
my build thread
Re: heads up
Beware of.
.hid's aren't a failure
Re: heads up
dan4 wrote:Beware of..
This is my understanding also.
Re: heads up
Taxi company in town just fitted aftermarket HID's
(cheap ebay kits in standard lenses) in all their cars as they told me whilst buying 8 packs of DRL's from us
Re: heads up
Hids are not a failure.
You need to have washers fitted and the correct lenses fitted and a leveling system fitted
Mr2 Rev1 tubby
my build thread
my build thread
Re: heads up
Proper HID lights with cut off shields, and the correct beam pattern are not an MOT fail.
Re: heads up
RedMR² wrote:Proper HID lights with cut off shields, and the correct beam pattern are not an MOT fail.
Correct.
If the manufacturer did not fit washers and levellers, then they are obviously still legal.
Let's hope MOT testers do their job properly and get the ebay shoppers with their Chinese poo HID kits off the road.
Re: heads up
Peter Gidden - SBITS wrote:
Let's hope MOT testers do their job properly and get the ebay shoppers with their Chinese poo HID kits off the road.![]()
Every single one of them.
Re: heads up
it's not going to happen is it, they'll just reconnected the stock bulbs for the test and remove them after
chris
chris
Re: heads up
They've changed a bit haven't they?? you can only fail a shocker if it's leaking, not on the bounce test and it's ok to have a broken road spring now???
Re: heads up
Peter Gidden - SBITS wrote:scooby seb wrote:it's ok to have a broken road spring now???
Really?Source please.
Wrong it was acceptable to have an end tag broken if it didn't effect the strength as of the 20th any broken spring fails again
Mr2 Rev1 tubby
my build thread
my build thread
Re: heads up
What are people's opinions on decent hid kits from the likes of hids4u?
Re: heads up
4ndee wrote:Peter Gidden - SBITS wrote:scooby seb wrote:it's ok to have a broken road spring now???
Ah that was it, i was only half listening when the tester at work was reading it out
Re: heads up
Peter Gidden - SBITS wrote:RedMR² wrote:Proper HID lights with cut off shields, and the correct beam pattern are not an MOT fail.
Correct.![]()
If the manufacturer fitted them, they will have projector lenses and cut-off shield as part of their construction.
I have seen nearly new vehicles dazzle with me their hids.
Not sure what the levelling system takes as a level reference but it does not seem right.
e.g.
Re: heads up
Most of them have self level devices that when you dtart the car calibrate themselves thenadjust whilst driving.
The big audis and things like x5s blind me too its horrendous,
but not as bad as chavs with e bay special kits thst drive me mental.
Its them who need targeting.
Mr2 Rev1 tubby
my build thread
my build thread
