[Mk2] [Turbo] connecting rod bearings help
hiya can you change your bearings from just taking your sumptuous off and other things or is it engine out work thanks
Re: [Mk2] [Turbo] connecting rod bearings help
jamesmr21987 wrote:hiya can you change your bearings from just taking your sump off
Yes
what ones would u suggest to use
PM Sean at Hurley Racing.
He keep King bearings.
TBH, all the prime, globally known makes are as good as each otherfor normal use.
jamesmr21987 wrote:hiya can you change your bearings from just taking your sumptuous off and other things or is it engine out work thanks
If they do need changing you need to check the crank for marks and wear too.
