If I buy a steering boss like the HKB below
charged wrote:Mine's probably screaming'stop raping me'
Finn wrote:Also, how is the HKB diameter? Is it supposed to be used with the original plastic column ie.does it fit inside it?
stenky wrote:.
.I don't fancy driving my two in salt and snow.
un1eash wrote:Not heard of anyone using the HKB boss before.There are known issues with some other ebay boss's as the indicator cancel doesnt work and indicator stork clearance
(i guess this depends on the wheel though)
I was using a momo boss and OMP 320mm superquadro D shape wheel but found it to small so its sitting in my garage now.
brawr wrote:I bought one of the generic ebay ones, quality really wasn't bad and it was very very easy to modify it to get indicators and horn working.I think they're just designed for later toyotas with slightly different self-cancel pins rather than being woefully badly made or anything.
Just fitted a 25mm spacer to bring my almost flat Abarth wheel a touch closer and now it's perfect.
