Changed the Clutch Master and Slave Cylinder and in the process my mate left the door open which drained the battery.
had to take it out and charge it up and it seems to be fine now.
When i got in the car last night again and started the engine the doors locked automatically which aint so bad as i lock them anyway, car locked up fine aswell once i parked it at the house.
This smorning when i went out the car opened as normal but when i parked at work it wouldnt lock again.
When i press the lock button the indicators flash and the alarm sets but both doors do not lock.
I opened the door and the alarm triggered but once i pressed the unlock button again the alarm went off as it should.
I had to lock the doors from inside the car and then set the alarm.
I didnt try reopening with the fob either.
Is there a way to reprogramme the fob again?
Ive had a look through the site and other threads are different problems with central locking
