Car is not charging battery, checked 3 pin plug with ign on, found one pin to be at 0v
Where does the wire go? Looks like it goes into the loom at the intake manifold.
toecutter wrote:Rev 2 Turbo
Car is not charging battery, checked 3 pin plug with ign on, found one pin to be at 0v(think it is black and yellow wire nearest the floor).
Where does the wire go? Looks like it goes into the loom at the intake manifold.Is there anywhere it usually breaks?
toecutter wrote:I have continuity between pin on plug for b/y wire on alt to the plug in fusebox on the thick b/y wire.But I'm only getting 0.4v at the alternator plug.
toecutter wrote:Across the terminals of ECU-IG fuse I'm only getting 0.2v, so break must be further up.
