So after around 4 years of ownership, I'm having to put my brilliant little MR2 up for sale.
I hadn't planned on selling the car for quite a while yet, or even at all as I wanted to turn it eventually into a track only car.
I was just given an opportunity and decided only a couple of weeks ago to buy another car.
But logistically I have no where to put the MR2 now
Japanese rev 3
Mileage
Taxed until
MOT until
Thatcham Cat 1 Alarm/Immobiliser
Just a couple of months ago in North Wales:
Mileage as of today 23/10/2012
S.R.R day earlier this year
Replaced:
Jmec ECU
Japspeed air intake
Bomex UAD180 lip
Potential one off
EBC Yellow Stuff Pads
EBC discs
Eibach rear camber bolts
TRD HT Leads
Toyo T1R Tyres
Front tread depth
Rear tread depth
Motul RBF 600 Brake fluid
BC Racing Coilovers
Whiteline ARB
Nardi steering wheel
Razo pedals
Alternator
Battery
Water pump
Oil pump
Cam belt
Clutch
Rear bearings
Starter motor
Drop links
Harness drivers side
Fire extinguisher
Spark plugs
Fuel filter
Dizzy cap
Summer 2009 stuff was done by Luke at Pacific Works.
All of the other tricky stuff was done by 3S, and simple stuff by me
I've tried to put down the dates as I remember them but stupidly I didn't keep a file of it all.
Good Points:
Well looked after car
Strong engine
Body resprayed from white to black last December, and wheels very dark grey/black.
Doesn't drink or leak oil
Folding electric mirrors
Leather
Annoying Points:
Advise softer spring set
It could do with full polishing to remove typical swirl marks.
10mph out on the markings for the odometer
Some complete berk clipped the passenger side rear wheel arch in the car park
Bad Points:
Air con doesn't work any more
No stereo
Right side of dash lights aren't working, just a bulb replacement required.
The geo was done last year at Wheels in Motion, if you're planning to use it on the road as I did, I'd advise their set up.
If you change the springs, or if I get time to, then you'll need to get this done again anyway but you can take the print out with you to get anyone to set the car up as it was.
Location
