I fitted Yoko AD08 tyres on the front and Bridgestone S02 rear both standard width, new discs with track pads all round but I havent done anything with the suspension yet so the first place I want to start is the anti roll bars, which would I be best off buying?
Im leaning towards the whiteline as I like that it has adjustability but is about 5 or 6 times more expensive then a second hand set of 19mm rev 3 ARBs.
The car is my daily drive plus about 1 trackday per month which is why I want to start with the ARBs.
I will be buying some camber bolts so I can adjust that to suit my preferences but these will be the only 2 modifications to the suspension for a month or so.
I also suspect the car has a viscous LSD fitted but im not 100%
