not sure if this is a fault in all mk2's but i recently removed my rear quarter side strips to replace them with the 1's with twin cam 16 turbo on.
anyway i had been having problems with rust bubbles on the rear end of my sills, and then when inside the car removing the strips and getting all the paneling out i found a big triangle of foam that is pushed deep down in to the quarter panel right were the rust problems had been, upon removing the foam it was soaking wet and covered in rust marks, so just a heads up for anyone having rusty sill problems do what i did and remove this bad design peico of water trapping foam
hope this helps someone
