engine out help
4ndee
engine out help
Post by 4ndee »
I'm dropping the motor out on Saturday to do clutch, cambelt, turbo and manifold, cam cover. Can anyone suggest anything else to do while it's out that's easier.
jasongtr
Re: engine out help
Post by jasongtr »
oil and water pump
alanmr2turbo
Re: engine out help
Post by alanmr2turbo »
drive shaft seals
4ndee
Re: engine out help
Post by 4ndee »
Were can I get hose from he'll?
Al-sw20
Re: engine out help
Post by Al-sw20 »
Toyota, or one of the vendors that sell genuine Toyota parts on here.
They should be line priced, the HFH and HFHOE were $12.00nzd each.
I'd also do fuel filter, thermostat, crank shaft seal, rear main seal, cam seals, dizzy seal.
IMO when your motor is on the deck. Do everything you can at once.
killerferret666
Re: engine out help
Post by killerferret666 »
On a rev 2 is it worth going to a metal gasket im soon to have my engine out, like the OP.
Harold
Re: engine out help
Post by Harold »
Core plugs also perhaps?
Steve-O 2007
Re: engine out help
Post by Steve-O 2007 »
Forged internals?
Cams?
4ndee
Re: engine out help
Post by 4ndee »
I'm getting confused with the hfh phoned Toyota today and they were useless they said they have no idea and only had one pic to show me. So which bits do I need?
Steve-O 2007
Re: engine out help
4ndee wrote:I'm getting confused with the hfh phoned Toyota today and they were useless they said they have no idea and only had one pic to show me. So which bits do I need?
If someone can give you a part number that would help you out (then you can just quote the number to them) :thumleft:
planted1
Re: engine out help
Post by planted1 »
Idler pulley,alternator belt.
jasongtr
Re: engine out help
Post by jasongtr »
lol, basically it seems if time and money are available just fully rebuild it
4ndee
Re: engine out help
Post by 4ndee »
Time isn't on my side needs to be working for Monday morning.
Need help its all but out just electrics left although not whether to take the loom out with the engine. Anyone help?
4ndee
Re: engine out help
Post by 4ndee »
Anyone?
feckdeamon
Re: engine out help
Post by feckdeamon »
Disconnect at fusebox, should come away easy enough.
