Brake upgrade query
Gad
Location: Castle Donington, home of fast cars and strange festivals...
Brake upgrade query
Post by Gad »
Fairly simple one, are the later spec front brakes a straight swap or will I need to change anything else?
Obviously I'll need new discs but do they mount the same as the early ones?
Found a website where the later spec brakes end up twenty quid a corner cheaper than the early ones so might as well go for the upgrade... :)
User avatar
Lauren
Re: Brake upgrade query
Post by Lauren »
Yes, but you need the caliper mount as well.
The Silver Fox
Post by The Silver Fox »
..... and the 1a dust shields will need to be removed/replaced as they wont fit over the 1b discs.
User avatar
Lauren
Post by Lauren »
To be fair you can just lose the dust shields.
Polypedates
Post by Polypedates »
New ones are now discontinued anyway - I had to weld mine up with new metal :roll:
elbon50
Post by elbon50 »
Lauren wrote:To be fair you can just lose the dust shields.
And save some weight \:D/
User avatar
Lauren
Post by Lauren »
Yeah about 40 grams a side less whatever rust they've suffered!
You, Peter are completely mental about weight saving! :tongue:
elbon50
Post by elbon50 »
Lauren wrote:Yeah about 40 grams a side less whatever rust they've suffered!
Every gram subtracts down Lauren :)
Paul says its possible to get down to 850Kg
