The rear wants to step out at all times and just feels loose.
Anyone else had similar issues?
oukie wrote:Silly question Tim but you checked the rear ball joints?
Mine are slightly worn(ie have minnor play) and I find I can step the back out a bit to easy even in the dry with Yoko's
Ive ordered a pair as thats about all I could find that wasn't 100%
Chris
PW@Woodsport wrote:I think what Tim is describing appears to be more than the normal Mk1 tail happiness.
jon_st205 wrote:Does it crab under braking or just under power?Could be a CV joint if open diff?
Finn wrote:Just a guess or two:
- tightened the control arm and strut rod bolts with the car weight on?
- wheel alignment OK?
- motor mounts?
PW@Woodsport wrote:So it definately has wrong parts on there, Tim if you look at the rear hub mounting point for the track arm(adjustable tie rods), on a Mk1A the mounting is quite close to the hub, On a Mk1b it sits 3 inches inboard.
I suspect you have the correct susbframes fitted, because you do need to modify those to fit them, my money is on the hubs being wrong.
This makes the relationship between inner mounting point/hub swing in a different arc to the lower control arm, which then makes the hub steer in/out on compression/extension.
