my car was offseason for over 3 months nearly 4.
my battery died over the winter even with a charger.
So i bought a new one.Decided to go for a small VARTA Blue Dynmic line with
42AH and 390 crank amps.
Today i started the car and it took quiet some rotations
Could it be that this battery is to weak?Or is it because air trapped in the fuel lines for the first few miles?Cant imagine another reason as i didnt change nothing else.
Never had this issue with the old battery.grounding wires are all new and thicker than stock
Car pulls strong and idles like a champ.
ok went to our garage today again to put in my new suspension.
After that i had time to check for my Starting issue again.
I tried another bigger battery,redone my Groundwires to toyota layout,checked my starter by unbolting it
Car still behaves very strange.
When i start it cold it takes like 20 starter revs to get started and then i smell much fuel from the exhaust.So it seems somehow it isnt possible to ignite the charge.
i asked myself if it could be temperature related.When i started once.
i melted my brain on the problem and cant find the solution.
Its like the injectors or the spark isnt right.
spark plugs are light brown and 1 year old,injectors are used,cleaned and checked for spray pattern by Bosch service.
tomorrow i will measure my tempsensor in the wateroutlet and in the intake manifold.
anyone got sugestions?temp sensor?IAC?
