I pull over and have a look, can't see anything, get it home and today had a proper look at it
Seems oil has been dropping down onto the alternator or has been dripping onto the driveshaft and flicking up onto the alternator, smoke pooring out of the alternator and whining now abit now.
rocker cover isnt leaking, seems its running down behind the alternator from somewhere and is dripping onto the driveshaft, although now smoke is there even after leaving it running to try burn any oil off the alternator although maybe its not getting hot enough to burn it off or its leaking?
oil level is fine so can't be losing much although has only just happened
is there a paticular item around there near the camshaft pulleys etc that could be dripping oil.
Any and all advise is much appreciated as not driving it until I have sorted it to save the risk of damage and also a smoking engine bay doesn't look the best lol!!!
Rev2 turbo for the record
