Sloshy spoiler...
riot68
Sloshy spoiler...
Post by riot68 »
Closing my boot the other day I noticed a watery sound, thought it was in the boot lid as last year had the 2 piece spoiler off and did some work. Took it off again and turns out it's in the rev1 2 piece spoiler itself, tried shaking it about from very angle and nothing will come out so have no clue how it got in and for life of me I cannot get the screws undone to take the 2 pieces apart, any suggestions? Tried an impact driver, maybe need to hit it harder :D ...
visual anarchy since 1990...
riot68.com
Quigonjay
Re: Sloshy spoiler...
Post by Quigonjay »
drill a drainage hole in the bottom :thumleft:
riot68
Post by riot68 »
What a good idea...
riot68.com
Yeah, had this before, if you remove the 2 screws from the inside of the boot lid that hold the spoiler there in the corners, water will come p1$$ing out.
riot68
Post by riot68 »
RedMR² wrote:Yeah, had this before, if you remove the 2 screws from the inside of the boot lid that hold the spoiler there in the corners, water will come p1$$ing out.
Undone these to take spoiler off and nothing came out, will do some investigating as have spoiler off and at home...
riot68.com
gazchap
Post by gazchap »
Have got the same problem with my Rev5 adjustable spoiler, sounds really weird when you close the boot!
I'll have to take a hex bolt to the spoiler do adjust and see if I can get the water out - bu88ered if I can work out how it got in there though! Shouldn't be anywhere that water can get in, surely?
riot68
Post by riot68 »
I drilled a few little Hols in the bottom then dig a jiggle & got most of.it out...
riot68.com
Nic
Post by Nic »
gazchap wrote:Have got the same problem with my Rev5 adjustable spoiler, sounds really weird when you close the boot!
Had the same problem with my rev 5 wing, water had gotten between the 2 uprights and cross piece.
Going to order some new seals from Toyota to fit between the 3 sections.
