[Mk2] [Turbo] BOV recirculation
nickg07
Re: [Mk2] [Turbo] BOV recirculation
Post by nickg07 »
Well it removes any lingering doubt as to whether your rocking a turbo or not!
Johnr32
Post by Johnr32 »
my 2 also came with a BOV which I removed as soon as the stock one came through the post. Just couldnt live with it, found it really annoying and wasnt to my taste..
Magic Beans
Post by Magic Beans »
Johnr32 wrote:my 2 also came with a BOV which I removed as soon as the stock one came through the post. Just couldnt live with it, found it really annoying and wasnt to my taste..
Did you notice any difference other than noise wise?
bugdialer
Post by bugdialer »
I bought my Rev 5 Turbo which is fitted with an HKS SSQV and i cringed all the way home due to the stupid woooooshhhh noise that it made, even at low revs. It made me drive slower because I hated the noise.
I understand that they are a quality product so I contacted an HKS supplier to buy an adaptor to fit a recirculating pipe, only to be told that they were not available. I didnt have the original Rev 5 BOV to retro fit so I had an adaptor made for the HKS unit. All is fine now with just a slight noise on lift off just to let people know that it is a real tubby.
Johnr32
Post by Johnr32 »
mine was a rev2 with only decat, exhaust and air filter so is fairly standard. I didnt notice anything tbh, it ran fine before and ran fine after too.
Spawn
Post by Spawn »
I think I'm going to remove mine during the summer :thumleft:
Driftlimits Performance
IMOC Affiliated Company
ok geek time..
like I said on another thread, the stock DV stays open until you've reached positive manifold pressure (during spool up) which in theory spins her up faster.
So THE best dumpvalve for performance is the standard one.
Spawn
Post by Spawn »
Now I just need to locate one :D
Magic Beans
Skywalker wrote:ok geek time..
Perfect answer. It might be fugly but if it's the best option it's the only way to go :thumleft:
Magic Beans
I guess the OEM re-circulating valve is the same for all revisions?
Johnr32
Post by Johnr32 »
Magic Beans wrote:I guess the OEM re-circulating valve is the same for all revisions?
It should be all the same.
Magic Beans
Magic Beans
One more question: What's the boost limit that the stock diaphragm can handle?
jon
Post by jon »
If you get a 2nd hand OEM BPV, just make sure it passes the checks in the BGB
Magic Beans
jon wrote:If you get a 2nd hand OEM BPV, just make sure it passes the checks in the BGB
Image Replaced With URL For Quote http://i403.photobucket.com/albums/pp11 ... _check.jpg
Will do, thanks :thumleft: It should hopefully arrive tomorrow.
Magic Beans
Some interesting reading I found on this, so thought I'd share - http://www.jekylhyderacing.com/bov.htm
Peter Gidden
Post by Peter Gidden »
Magic Beans wrote:One more question: What's the boost limit that the stock diaphragm can handle?
Had many customers over the years running 22-23psi on stock BOV. Remember, as boost increases, pressure keeping it shut increases. The OEM BOV can't leak under pressure, regardless of the pressure achieved.
Magic Beans
Begs the question of why on earth you'd trade that for a good awful noise?! It's all subjective I guess and age :lol:
Peter Gidden
'Cos it impresses the chicks at the Friday night KFC cruise innit :mrgreen:
Magic Beans
It does? Might keep it then, or buy a bigger one :mrgreen:
Hopefully tomorrow Royal Mail will finally deliver a parcel which will end the noise for me. :pray:
