Door handle fixing bolt & stud
xtremepix
Post by xtremepix »
Hey,
I've just fitted a new drivers door to my 2. Unfortunatly when removing the door handle and lock from the old door, one of the fixing bolts was rusted solid. Its a 10mm bolt head (I think, may be 12mm), with a stud insert piece which has a rough edge, like a file.
Does anyone know where I can get hold of one of these? Got my door handle on, but have to be careful when opening!!
Thanks again
Slarty
Re: Door handle fixing bolt & stud
Post by Slarty »
I don't know where you can get spare of those types of stud. I know what you're refering to though. The end that has the appearance of a round file is a push fit into the handle, and the rough surface is what holds it captive in the handle.
The only two suggestions that I can think of is to either use a similar size normal stud (M6, M8 or whatever size it is) and bond it into the hole using araldite or similar, or get a spare handle from a breakers or someone breaking their car on here....
xtremepix
Post by xtremepix »
Yep thats the bit! I'll keep looking for a spare one knocking about on here, otherwise I'll try that idea... thanks!!
riot68
Post by riot68 »
Just post in the wanted thread, one of the guys breaking a car will have a spare they can send you for a few quid i'm sure. I've had loads of little bits ad bobs of people, good luck...
visual anarchy since 1990...
riot68.com
