[Mk2] [NA] noise from boot?rear wheel? exhaust area sounds like a drum ??????
modgod
Post by modgod »
like i say on rough ground and bumps a noise like the banging of a drum happens............could it be sound proofing over the exhaust, doing my swede in really irritating.
Quigonjay
Re: [Mk2] [NA] noise from boot?rear wheel? exhaust area sounds like a drum ??????
Post by Quigonjay »
could be a number of things but i would check the drop links first
Draven
Post by Draven »
Wheelbearing??
djpkins
Post by djpkins »
must have a certain amount of resonance if it's "sounding like a drum"...topmounts, loose exhaust backbox?
modgod
Post by modgod »
all my top mounts are new as ive just had fittd tein super street, drop links new too, but as its being track prepared and everything has been stripped out all the soundproofing i can hear absolutely everything, but this is a new one on me, been messing around above the exhaust and i think its a loose heatshield banging off the bottom of the boot and because all the boot linings gone this is what i thinks making the drum noise, ill put it on the ramp saturday and have a proper look round.........wierd it is.
djpkins
Post by djpkins »
so you've got really stiff suspension and you've stripped all the sound insulation from the car...
modgod
Post by modgod »
yup ha ha ha, and im moaning about hearing every little thing......but seriously this ones never happened before now.
djpkins
Post by djpkins »
ahhhh hahaha ahhh that old chestnut...listen Weller, better getta lambretta...lol...prob just the car shaking itself to bits old fruit, as you suggested a heat shield or simmilar is having a party underneath there...my car comes up with some pukka beats at times :thumleft:
modgod
Post by modgod »
yeah prob, it is a titty shaker.............ill just take the lot off sat, get rid of it all, loose a bit more weight and just get some tape for the down pipes, but if it turns out to be a wire in the boot shaking up and down on the floor pan i wont be amused !! :D
Canopus
Post by Canopus »
It could also be the rear anti-roll bar bushes. Mine made this noise. Grab the ARB and see if you can move it by hand, if you can you need new bushes.
Unfortunatley you will need to drop the sub frame about 1" max to get a spanner in there. The subframe bolts are long enought to do this (take one out and you will see how much you have to play with).
It's not a difficult job and should only take about 1/2 hour to 1 hour.
Good luck
Geoff
AlexD
Post by AlexD »
Tell you what I had recently, The book was rattling slightly, never realised it myself, mechanic spotted it and adjusted the rubber mounts on the inside of the boot lid itself. :)
JohnnyC
Post by JohnnyC »
AlexD wrote:Tell you what I had recently, The book was rattling slightly, never realised it myself, mechanic spotted it and adjusted the rubber mounts on the inside of the boot lid itself. :)
After my suspension overhaul, I had a slight bang when coming off speed humps.
Turned out to be the rubber mounts on the boot lid (that I'd fiddled with a week or so earlier) :oops: :mrgreen:
dantheman
Post by dantheman »
this banging on a drum sound, could you also describe it as a metallic pop, kinda like the sound that the top of a jar makes when you push in the air seal ring bit in the centre?
If so its the sound of your now weakened floor pan popping under load. test it out, push the floor pan from above or below and it should pop.
DAN_REV1_TURBO
Post by DAN_REV1_TURBO »
Weakened floor pan? From the floor of the boot you mean Dan? Because of stripping it out? All I remember when I stripped my boot out was carpet and soundproofing, and I think some kind of boarding on the bottom. I didnt think it would have any effect on the strength/structure of the boot though? I do not get this sound and my car is pretty stripped out.
dantheman
Post by dantheman »
modgod wrote:its being track prepared and everything has been stripped out all the soundproofing i can hear absolutely everything,
No im referring to the cabin floor. If all the hard sound deadening has been removed from the floor then the floor has gone from an ~7mm 2 layer composite of metal and plastic to just 2mm of metal. It becomes a lot weaker and less stiff and starts popping.
ive removed the sound deadening from the floor of 2 cars now, and after doing both i started getting a clunk which i thought was either a loose subframe or something being thrown about in the boot. You hear the noise from behind you but its actually directly beneath you.
