CAN YOU HELP just changed head gasket and timing belt on my rev1 turbo
it will start and run for about 10 seconds and then cuts out,you can turn the key and it starts straight away again runs for 10 seconds and cuts out again PLEASE HELP ME
is it owt to do with the fuel pump??? the igniter kicks things off then the ecu, after recieving a bunch of signals, fuels for the tickover...not after 10 seconds though.
