Genuinely a regrettable sale; this is now my third car
Imported in 2007, I am the second UK owner
Currently sitting at 101,665 Miles, although this will increase slightly as I'm still driving it.
MOT until August
This has been my Daily driver until the beginning of December; I have covered 16,000 miles in just under 18 months.
Working Air condition, important on a black tintop.
There is a complete and comprehensive UK history and a folder full of JDM history.
Recent work includes but not limited to;
Cambelt and idlers replaces at 90,000
Pipes from Hell redone
Oil changes at roughly 4,000 mile intervals
Serviced at 99,389
The ECU failed and was replaced by Rouge
Rear Calliper replaced.
All Oil leaks fixed, numerous new gaskets.
16" Sprint Hart CP-R alloy wheels, 7J front, 8J rear, ET35 offset, and 73.1mm to 60.1mm spigot rings,
Toyo Proxes T1R tyres front and back, over 6mm of tread on all 4 tyres.
UK spec struts with Eibach progressive springs and KYB damper inserts.
TRD 22mm anti-roll bars front and rear.
Working LSD
Greddy Profec B spec 2 boost controller.
Apexi power intake.
Motoria decat downpipe.
Stock exhaust.
Greddy side mounted intercooler with improved GTS-Chris shroud and EMS powered intercooler piping.
Hydrastar braided brakelines.
HKS SSQV blow off valve.
Omori 45mm boost gauge fitted into the instrument cluster.
UK spec 160mph speedometer.
Two's R Us clamping delimiter.
Revision 1 black roofliner, interior light trim and sunvisors.
UK spec full leather seats and leather doorcards.
Toyota Celica 7th generation steering wheel.
Toyota sub woofers fitted behind the seats.
Door mirrors converted to be retracting, and are now heated using revision 4 UK MR2 parts.
Revision 5 boot spoiler.
Revision 5 front arch wind deflectors.
Crystal front indicators.
Raybrig style
Toyota Supra gunmetal grey Toyota emblem.
Offside reverse light converted into the rear foglight, with Toyota rear foglight switch fitted and the instrument cluster symbols modified to give the tell-tale light.
Toyota Yaris mist effect windscreen washer jets.
Cobra 4138HF category 1 alarm and immobiliser.
Waxoiled underside.
JDM Wind Deflectors
Mud Flaps
Man in Datsum mats
Alpine Head unit with USB and Ipod connections.
Samsung Galaxy S II Phone holder fitted
The clutch release bearing is slightly noisy, but it has been like this since I have owned the car.
There was a knocking noise coming from the offside rear, however this has now gone.
There is rust creeping in on the nearside rear arch
The engine lid is a completely different colour; it is like it has no lacquer left.
The boot lid is scratched where the badge has been badly removed.
There is a scratch on the offside roof panel where it was
The wheels are looking tired and could do with an refurb.
Can't seem to post them; looks like I need more posts.
