oil in spark chamber 3
Baker
Post by Baker »
as per title..only a little bit though. rocker gasket?
gtschris.com
Re: oil in spark chamber 3
Post by gtschris.com »
Baker wrote:as per title..only a little bit though. rocker gasket?
yup, them dam screw allwys come loose, i got a friend who works in a fastner trade supply company working on a hex fitting upgrade.
www.gtschris.com
tel: 01670 737080
mob: 07786070103
Fizzy
Post by Fizzy »
imo not likely - more like plug not seated correctly.
Jimbob
Post by Jimbob »
had same prob, spark was jumping and started too missfire. The old gasket in the middle (centre two plugs) was leaking. Got a new kit, the old gasket was hardened and poo basically, got a nice new supple one and cleaned the joint faces, problem solved
james
gtschris.com
Fizzy wrote:imo not likely - more like plug not seated correctly.
leaking cam cover gaskets due to screws coming loose is very common on 3sgte rev1/2 rev3 better.
www.gtschris.com
tel: 01670 737080
mob: 07786070103
steve b
Post by steve b »
must admit one of my first mod to my tubby engine was getting the hex bolt kit from twosrus.com I know its alot for bolts but I found it hard to source the correct style of washer else where.
LuizeGT
Post by LuizeGT »
ive found this out recently, swapped my rocker gaskets as i was getting leaking in chamber 2 and 1. they were as solid as wood! they snapped easily, but my bolts keep coming loose and its getting on my nerves :(
whats the difference with these hex bolts?
steve b
Post by steve b »
diference is these can be tightened up properly :D
Jimbob
Post by Jimbob »
You can get the standard ones tight if you use a philips drive bit on a torque wrench (or standard wrench). I'd say its equally important to check them every now and then and check for oil leakage. Remember also tighten in an opposed sequence i.e opposite corners and check each bolt once ther all in. Mine are nice and tight now, and seem to be holding fine :lol:
Baker
Post by Baker »
thanks chaps. new gasket it is then.
