Alloy Radiators
Draven
Alloy Radiators
Post by Draven »
Has anyone had any experience with these? My rad has a hole in it pretty sure a stone flicked up and pierced it.
So It needs replacing. now there are these on ebay
http://www.ebay.co.uk/itm/TOYOTA-MR2-SW ... 1c20132edc
I'm wondering if they are any good? To me they look ok although the sensor hole is blocked off is this important?
Then there is the ones MR2-ben does
http://www.ebay.co.uk/itm/NEW-EXTRA-COO ... 3f0b370462
Which i'm more comfortable with trusting so what are peoples thoughts.
Re: Alloy Radiators
When my rad goes down, I'll be replacing with an alloy item and twin spal fans :thumleft:
Draven
Re: Alloy Radiators
Post by Draven »
RedMR² wrote:When my rad goes down, I'll be replacing with an alloy item and twin spal fans :thumleft:
I think i'm sold on the alloy idea.. because it weighs less than half of the standard one but which one do you think is better..?
The top ebay one there is 100% alloy but has the sensor blocked over.. Mr2 ben's one has a Alloy core and mild steel tanks either side.. I'm leaning towards Mr2 ben's one.. I just don't know. 8-[
Draven
Re: Alloy Radiators
Post by Draven »
Just ordered the MR2-Ben one as it has the hole for the sensor.. :thumleft:
steve
Re: Alloy Radiators
Post by steve »
i've got this one (same as mr2-ben's one), shame they set the bleed valve in the wrong place so you can use the pipes to bleed it like stock #-o
http://www.ebay.co.uk/itm/TOYOTA-MR2-Mk ... 41572dfe0e
Draven
Re: Alloy Radiators
Post by Draven »
steve wrote:i've got this one (same as mr2-ben's one), shame they set the bleed valve in the wrong place so you can use the pipes to bleed it like stock #-o
But it is ok other than that right ?? because i've just ordered one..
Drifter
Re: Alloy Radiators
Post by Drifter »
Radtech Racing in cannock, if you want a top quality rad
Mine cost me £400
Draven
Re: Alloy Radiators
Post by Draven »
Drifter wrote:Image
Mine cost me £400
:shock: I'm not sure I can warrant £400.. I'll have a look at the Mr2-ben one when it arrives on monday.
Drifter
Re: Alloy Radiators
Post by Drifter »
Yea it is expensive, but perfect pattern copy :thumleft:
Draven
Re: Alloy Radiators
Post by Draven »
Drifter wrote:Yea it is expensive, but perfect pattern copy :thumleft:
It does look lush :mrgreen: If i had the cash I would get one of those. :thumleft:
Re: Alloy Radiators
Yup, Radtech = 8)
