Found a good glitch on gt5 so you can get
£250,000 every 10 mins.
few thing that you have to do, first is to set your controller to turn off after 10 mins of no use, then you have to start gt5 every day to get the log in bonus.
on the fourth day you will get up to the 200% race win bonus.
Now if you go onto the new b-spec special event
(the online events) go onto the high speed ring and use either a opel speedster turbo
(all mods exepct any power one) of the acura nsx
(again all mods except the power altering ones) and turn down the power so that your on 395PP.
once you have started the first race turn your router off so that the ps3 drops the connection and you can then turn it back on again.
You have to do this as you should only be able to have the 200% bonus for 5 races but if your not online then id doesnt know how many you have done.
Now you can turn the channel over watch telly and when you notice the controller turn off
press the ps button
press x
(few seconds pause)
press x
(few seconds pause)
press O then x
(pause)
press x
(pause)
press x
you can do this up untill you get
£20,000,000 which is the limit but you will still be able to race and get 30000 exp points
Hope you find this usefull
