I'm going to advance the timing back to 10° and see if things richen up again, but just wondering if anyone had encountered anything similar.
Reason for retarding the base timing in the frst place was possible det at 1.3bar, even with a BMIC
Cheers.
allan welsh wrote:1.3bar on the stock rev1/2 turbo? Impressive esp if it's the stock head gasket
Martinbattye wrote:at 10degrees the ecu may drop into knock fuelling.at 8 it may not.
youd have to scope inj PW to find out.
but from a 10 to a mid 12.is a lot of difference in fuel duty.
but as you say could be pump related.
RichLee wrote:I think you need to tune the car correctly first.
Stock Injectors
Stock CT26 running 1.3bar
Stock ECU
Stock AFM still fitted?
And your wondering why your running lean top end?
Turn the boost down, get your Link fitted, fit the Walbro and please god upgrade the injectors! Then wack more boost through.
I'm surprised you haven't thrown a piston yet tbh![]()
jimGTS wrote:if this is a stock ct26, it wont be running more than 12psi by redline anyway, so 19psi or not to start, it will still dip to 12psi by redline.
unless of course your talking about a ct26 hybrid, which is a different story.
