1 of my 4 rear hub bolts that hold the wheel one has sheered off
Can anyone tell me if I need to change the whole hub or just the bit that has the bolts going through it.
Paul
paulcas wrote:Hi,
1 of my 4 rear hub bolts that hold the wheel one has sheered off!!
Can anyone tell me if I need to change the whole hub or just the bit that has the bolts going through it.And if so, how do I replace it.
Step by step guide would be good, with photos would be even better
- thanks.
Paul
frogger wrote:CTP(Cheap Toyota Parts) or a Toyota Dealership.
And consider replacing all 4, unless that one only sheared because of a force put upon it which you arecertain
has only ever been put on that stud.
Wheels have been known to come off at speed due to sheared studs, so better safe than sorry
