On the fat PS3 turn off the unit from the back switch then hold the eject button and turn it back on. It spins up the fan to silly speeds for a few secs blowing out a load of crap.
Mine sounds a bit better now. Never knew this and thought I'd share.
Ps3 fan test - just cleared out a he'll of a lot of dust.
Re: Ps3 fan test - just cleared out a he'll of a lot of dust.
You're hardcore
http://www.youtube.com/watch?v=0Oo7nfUuFB4
Works for the slim too apparently, although as there's no on/off switch at the back you have to unplug/plug the power cable instead.
lol
Well i did a bit more digging and this post on a forum makes the most sense to me.
alrught down to business, heres some background on me - i have been working with microelectronics for almost 6 years now and took advanced electronics and robotics in high school, and i have done circuit design for the past 3 years
inorder to make the fan go this fast the system is NOT OVERHEATING WHATSOEVER!
basically how it works is that the motor in the fan is controlled by a speed controller which part of the ps3's onboard systems control, so when the temperature goes up, the thermister/thermocouple detects the temperature and the ps3 tells the fan speed controller how fast to spin the fan.
when you use a "fan test/clean" mode you are telling the ps3 to overide the software that calculates fan speed based on temperature and to tell the fan controller to kick the fan up to 100% speed therefore it is IMPOSSIBLE TO GET ANY DAMAGE FROM A FAN TEST MODE PERIOD!
the most that COULD happen is the fet's in the motor controller could burn out due to use of this option which could render the fan inoperable, but so can normal use.
in other words: the fan test mode couldnt damage the system any more than running it normally.
I agree actually
Roll on PS4 in 2013
Roll on PS4 in 2013
does it stop itself? and whendo you release the eject button? after it speeds
up?
up?
Mr2'less
Stops on its own after a short time, if you've got a PS3 out of warranty then its better to open it up and vacuum out the dust and crap and stuff
I thought that was just used for force ejecting disks stuck in ylod machines
Engine rebuilt by: Steve Horrocks & Andy Jones
Engine mapped by: Ryan@2bartuning (330 bhp & 325 lbft @ 1.4 bar)
Current Status: F****D
I just did it, it worked fan spun up to warp speed but no dust came out i'm dissapointed.
i had my fattyps3 for 4 years now and never done this or cleaned the vents, might try thins and see how much crud comes out.
Much better to open it up and vac out all the crud, there's plenty of guides on YouTube on how to strip it down
DannyN wrote:Much better to open it up and vac out all the crud, there's plenty of guides on YouTube on how to strip it down
You dont realise how much dust is there when you open it up.
easy or hard to open up? Last time i tried opening a ps3 controller the thing never went back together again and swiftly went out the window, followed by the bin..
Its easy to open up and put back together, I've got a good link somewhere I'll post it when I get home and check my bookmarks
Google or youtube are your friends
Might do mine tonight...
Used this vid to take apart my fat PS3 and gave it a good clean.
http://www.youtube.com/watch?v=to8aTNIKWOM
Now its like new when you can barely hear the fan!
pk_090 wrote:easy or hard to open up? Last time i tried opening a ps3 controller the thing never went back together again and swiftly went out the window, followed by the bin..
Tell me you live on the 50th floor in a block of flats?
Mr2_NA wrote:pk_090 wrote:easy or hard to open up? Last time i tried opening a ps3 controller the thing never went back together again and swiftly went out the window, followed by the bin..
I'm more concerned as to why he threw the bin out of the window after the controller.
