[Mk2] [Turbo] water running down sump
chirlie
Post by chirlie »
hello guys
was wondering if any of you kind fellows could help me with my problem :lol:
ok so i changed coolant and flushed system ,now its all back together i have a constant drip coming down my sump next to fan belt #-o .
My friend thinks this could be the water pump but im just not sure ](*,)
ashley
Re: [Mk2] [Turbo] water running down sump
Post by ashley »
+1 for water pump
TRINDA1664
Post by TRINDA1664 »
Sounds like the water pump, the same ad just happened to mine. Take the top cambelt cover off and if you see water on the pulley or around that area you know it is that.
chirlie
Post by chirlie »
Thanks guys :thumleft: will set about taking it apart soon as the rain goes off :cry:
