frogger wrote:Before you'forget about fixing it', there are some common faults and fixes yes.
The most common is covered in the relearn procedure, don't know if it's documented on here but it certainly is over on spyderchat(where there is a vast amount of SMT knowledge) and the info has also been pasted across to mr2roc IIRC
