How do you dismantle a T-BAR Panel
TUR80
Post by TUR80 »
One of my Panels is rattling abit, does anyone know after taking out the 2 small side screws what to do next as I don't want to force anything. Also does the flip handle pull off? Haven't tried to do that yet but I reckon thats what is restricting me removing the cover?
:-s
Mark Edwards
Re: How do you dismantle a T-BAR Panel
Post by Mark Edwards »
Yes the handle comes off. There's a horseshoe shaped clip that needs to be removed, not easy but also not too hard.
xxxx, AM TUNING, sbITs
CosmosblueMR2
Post by CosmosblueMR2 »
to get this "clip" out that mark is mentioning.. get a cloth and with the handle at 90 degrees to the edge of the tbar (basically in the release position).. work this cloth in a see-saw action under the handle between it and the t-bar.. pull towards you and you will work this clip free... you can then take off the handle and then the cover ofver the workings.
to reassemble.. just pop the handle back in the same position and carefully wedge the clip back underneath it - it will ping back into place and outta sight.
HTH
cheers
Frank.
Car now Sold :cry: damn 5th Lumber Disc !
TUR80
Post by TUR80 »
Sorted thanks \:D/
