What fuel pump for Supercharger conversion?
DNOS808
Post by DNOS808 »
Hi
I am converting my Mk1b to a late model 4agze from a Corolla Levin. The engine is standard apart from the usual bigger SC pulley.
I have taken the tank out and removed the standard fuel pump. Does anyone have an idea of what flow rate will be required for the SC engine?
I have been told that the Walbro 225l/hr is massively over spec and that the return lines will not be able to cope! Fensport sells a 176l/hr pump and some people on the Corolla forums recomend the Walbro GSS310 that flows 115l/hr.
Can anyone shed any light on this matter?
MartG
Re: What fuel pump for Supercharger conversion?
Post by MartG »
Mine has the Walbro 225l/hr one in, and runs fine :thumleft:
Neil_turbo
Post by Neil_turbo »
I have walbro 255 in my 1.5 and it reuses hard return pipe fine
squeezebox
Post by squeezebox »
don't use the large pulley on the levin, the s/c pulley is smaller than the earlier gze, it'll the s/c will max out long before the engine rev peak. that's what i experienced anyway.
cartledge_uk
Post by cartledge_uk »
squeezebox wrote:don't use the large pulley on the levin, the s/c pulley is smaller than the earlier gze, it'll the s/c will max out long before the engine rev peak. that's what i experienced anyway.
Thats true, but you would drive a charger on the low torque, not on the revs to maximize the power.
With a larger crank and later spec charger pulley the charger exceeds it limits around redline too.
MartG
Post by MartG »
In my experience its more a case of the intercooler reaching its limits rather than the SC itself - improved intercooling allows the SC to deliver useable boost right to the redline. My Levin engined trackcar has a Subaru chargecooler fitted along with the big pulley
