I know a lot of you have seen the onboard footage from spa so i thought i would post up a link to the results from the race at spa so you can see the class of cars we were racing against and remember this is in an n/a car not a turbo, on one of the fastest circuits in europe,take a look at the cars that finnished behind us then let someone tell you that MR2 s dont handle in the wet http://www.ris-timing.eu/~circuit//summer/2011/6r.htm
This probably has to be the best result an MR2 has had outside of japan and most of the thanks has to go to AW TRACKSPORT for a brilliant handling car and RISING SUN RACING (RSR) for such a well set up engine,well done guys
