You really need a mate to operate the hand brake while you inspect the caliper.
.my rear left used to bind and the disc has more grooves than sashas record bag.
.lol.
.you'll see and feel if there is any sticking going on, get your hands around
the handbrake mechanism.
The rear caliper can be removed from the brake cradle by undoing the 2 12mm bolts that hold it onto the sliders.
.it will still be attached by the brake line and can be tie wrapped up out of the way.
A pound to a penny says that it's the bottom slider that's siezed.
.spray copious amounts of releasing oil down the rubber gator and leave it stand for 10 mins.
.then you'll need to try and work the slider loose by twisting it back and forth with a long spanner or socket and breaker bar.
.it will eventually unsieze and may loosen up quite a bit.
.but I tried for hours to actually remove mine to no avail.
.brake fluid is also another good releasing agent.
It's a good job to get stuck into if you want to be more hands on with your motor.
.you learn a lot more by doing and seeing.
.and for a few hours work, you could save yourself a few bob.
