[Mk2] [Turbo] No P/S after rev3 conversion
joola89
Post by joola89 »
Hi guys,
I've just completed a rev3 conversion from a rev2.
I've lost power steering. Someone pointed me in the right direction with no joy. I understand that ecu is sending or not sending the correct signal to p/s.
How do I fix this? I read a thread somewhere but I lost the url.
Help please. Thanks in advance.
Shmed
Re: [Mk2] [Turbo] No P/S after rev3 conversion
Post by Shmed »
Can you post a pic of the firewall behind the boot carpet (with the ecu on it)? I looked at mine tonight, but as the loom was out of the car, I think the bit you need to unplug is out of my car.
It's not the ps relay you are looking for I don't think. It's a black plastic box.
Like I said though, Ryan.g will be able to tell you for sure.
January 2014
May 2015
Still in the garage...
joola89
Post by joola89 »
As requested.[/img]
joola89
Post by joola89 »
Ryan.g?
Have I pm'd the wrong guy? Lol
Not gazyang? He did sound a little confused...
Shmed
Post by Shmed »
Hmm, not sure who Gazyang is..... Ryan.G sorted mine, and iirc, the black box in the bottom right of the picture is the offending article. Unplug that and it should sort you out I think.
January 2014
May 2015
toxo
Post by toxo »
The little black box in the corner is the fan controller, that won't help you :)
It will be something to do with the PS and PSCT pins on the ECU. When I converted to an ST205 ECU I had to disconnect PS to retain power steering.
Shmed
Post by Shmed »
Really? I'm sure when Ryan fixed my PS issue, he didn't have to rewire anything. He just opened the boot, unplugged something and that fixed it.
January 2014
May 2015
joola89
Post by joola89 »
Pmsl. Definitely Ryan , not Gaz.
Ryan said "Remove pins PS and PSCT from Ecu connector and it will work bud", will give that a try once the sun pops out.
Wohoo.
Thanks guys.
Shmed
Post by Shmed »
:oops: sorry for sending you up the river, I obviously wasn't paying attention to what he did...
January 2014
May 2015
h20490
Post by h20490 »
Did you get it sorted?
joola89
Post by joola89 »
h20490 - no i haven't got it sorted.
I made a hash of it. Cut three wires and no joy. I don't have the tools to remove the pins properly.
I failed electronics at school see....
Using the image below, I cut the PSCT.
Nice and easy, it's the middle one.
Now I've got 50/50 chance of cutting the correct one. From the middle, skip one and cut. Guessed wrong and did the same the other way.
No joy. I know this is correct ecu block because when I disconnect it and move the ignition to position 2, I have P/S! Hurray... but obvisily the engine doesn't run for long.
Now have i got a different harness? My connector block below:
Or... is the ECU pinout completely wrong?
Going to end up cutting all the wires at this rate. Where am I going wrong?
joola89
Post by joola89 »
Sharing the wealth. It's the green and blue, wire with white dots. Sorted. Phew.
h20490
Post by h20490 »
Woohoo! :D
Return to “Electrical”
